4.0 OHV Dyno w cam upgrade
clowe1965
10+ Year Member
Read it and weep gents.
Stock 200k bottom end with hiflo oil pump
422 cam, beehive springs, non-professionally ported heads, shaved .030 so it should be around 10.5:1. stock everything else except it's straight piped from the y and back. 158@4500 and 212@2900
@clowe1965
• Automatic or manual transmission?
• what size tires?
• which gears in the axle?
• stock exhaust?
• electric fan?
@clowe1965
• what size tires?
• stock exhaust?
• electric fan?
Manual 2wd, running with auto ecu
3.27 gears
225/40/r15s
Straight piped exhaust dumped before the axle
No mechanical fan.
Stock airbox
422 cam, beehive springs, non-professionally ported heads, shaved .030 so it should be around 10.5:1. stock everything else except it's straight piped from the y and back. 158@4500 and 212@2900View attachment 136974
I've seen a lot of people say that they added a cam, but never see anyone share dyno results.
Now to decipher it.
The 4.0L OHV makes a 160hp. There's generally a 10-15% loss of horsepower to the wheels with a manual. In that case, I'm assuming you're 173-181 horsepower which is a gain of 13-21 horsepower. Sound right?
  • Like
Reactions: gaz
@clowe1965
I agree, 158 measured @ the brake is approximately +20+/- HP corrected for transmission loss, for the cam 😎
Good job, thanks for posting the slip plus set up 🙂🙂🙂
Event Coverage
TRS Merch
