- Jun 13, 2025
- Denver, CO
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.9 V6
Hi All,
Been enjoying daily driving the truck for the last couple months without needing to replace anything, perhaps I got ahead of myself:
1) I've been noticing a small amount of oil puddling after each drive lately and as far as I can tell it's coming from what I read to be the valve covers (per other forums I have been researching, the identical grey covers on either side of the intake manifold, photo attached. First project truck... bear with me). There is some smoke from what I presume to be oil hitting the exhaust manifold after driving, and an odor. There seems to be come controversy online about cork vs. rubber gaskets but the discussions are typically outdated. Just curious if this is as easy of a replacement as it looks, and if there are any clear winners when it comes to replacement gaskets here. From what I read, may be going with some RTV around the bolts as well in case of any warpage.
2) With winter approaching and the truck running generally well I have started to look into the 4WD system. I have auto hubs, which seem to be working at this time (with 4WD active, my front wheels are binding when attempting a sharp turn). However, there is a horrendous clunking when I shift from forward gear into reverse and apply throttle, or when I give the front axle any sort of real power. Here is a video showing this. First guess is U-Joints, which have been replaced in the back, but not the front... transmission mount is also new. Would anybody with more expertise be willing to provide their consensus? I have read quite a bit about the perks of manual hub swapping and am curious if this is something I should be considering before the Colorado snow arrives.
Any/all help and information are appreciated. Thanks ahead of time!
