- Oct 22, 2025
- San Jose
- State - Country
- CA - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock
Hey all, I've been having some overheating issues with my truck (210k mi), even after unloading the parts cannon. Does anyone have any ideas? It only overheats up prolonged inclines (rpm at 3500 for 5+min), and never at idle or freeway speeds. The heater works great after I unclogged it, and the issue persists regardless of AC use. I've not let the temp gauge get to redline since before I replaced any parts, but only because I go slow uphill and never floor it. It would definitely overheat if given full throttle.
The engine was rebuilt less than 10k ago. No exhaust gasses in the coolant, according to my test kit. Head gasket is good. Upper and lower hoses are both firm, and hot/warm respectively. Plugs, wires, and coilpack replaced 500mi ago.
Here's what I know is wrong with the truck, if it helps:
Vacuum leak somewhere, and small exhaust leaks in several places.
Fuel filter is old and possibly never changed. I have the new one and will replace.
The previous owner used the wrong coolant and practically never changed it. The metal coolant pipe on the top left of the block has a lot of corrosion.
Upper and lower hoses are old and had some residue before I cleaned them.
Potential EGR, PCV, and crankcase ventilation problems. Haven't confirmed, but hoses are cracking a bit
Thanks everybody for your help. This truck is like a stray dog to me: formerly abused and I love it to bits, but the lingering problems are very frustrating
