Cobfused on 95 Cam Synchronizer
West Baden Springs
IN - USA
Vehicle
Drive
Hi yall im new here and glad to be! I've been reading up on the 95's synchronizer replacement. Mine has the see through glass. I've read the threads on replacing it but im unsure about which end of the vane goes on the far left mark, the short one, when installing the synchronizer. Now when I stab it in it should be set where to makeup for the helical shape? Pass the small mark or is it supposed to rotate back to the bigger mark thats offset? My truck is apart now and im worried to death i wont get this set right. I had it at TDC when I pulled old one out and now I have it turned 26 ATDC (34 mm). I took pictures of the old sensor and the one in the truck had an orange highlight on the vane that lined up from the big half mark to the smaller mark when I pulled it out and was lined up so. So I set mine the exact same way and after it seats whete should the vane be pointing? The leading end on the small mark right? Help loo
I've also read the other threads on setting it. Everyone is telling me togo in the way it came out but the manual is saying 26 degrees ATDC. So im very confused of the importance of setting it ATDC vs just TDC
I’ve never done one with the window. Seen them but never did them. I’ve replaced non-window cam synchro assemblies, those you put at TDC, pull the sensor off the top and put an alignment tool on there, then stab it in and snug it down.
That said, make sure there’s no wobble or play in the synchro assembly other than the oil pump drive at the bottom
Event Coverage
TRS Merch
