- Aug 8, 2025
- Pelham
- State - Country
- AL - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 4.0 V6
I can use some help. I have a 1992 Ranger 4.0L that I drove to test out it's new fuel pump. When returning home the coolant reservoir overflowed after the engine idled several minutes in the driveway. A few days later I replaced the thermostat. It did not solve anything. The engine heats without warm water to the radiator or heater. Can a water pump go bad without leaking or making noises? The vehicle has sat garaged several years. I have never had a clogged radiator and there is no signs of corrosion within the radiator that can be seen. There is no signs of coolant in the oil at 230k miles. Thank you for your time.
