BW 1354 help
nastysoapdish
5+ Year Member
ASE Certified Tech
oregon
Does anyone know if the ring gear from an early 4 pinion 1354 is the same as a later 6 pinion? Bought the t case off a guy and didn’t realize it was an early case till I tore into it. I’d assume it is but just hoping someone will verify.
This is a 6:
BW 1354 help
This is a 4:
BW 1354 help
One of those is a 1350 and the other a 1354, but the casting is the same except for where the front output goes. The back half casting on a 1354 Actually still has the same part number.
The 4 gear kinda looks like a little machine work would let you make an 8 if you wanted.
that looks like a 1350 and a 1354.
those are indeed different. the 1350 only came with 4.
the 1354 otoh.....has the same 6 sided carrier and gears whether 4 pinion or 6.
it is interchangeable
This was the planetary set that came out of the 1354 I tore into. Looks like the same as what’s in a 1350.
BW 1354 help
And this is the ring gear that came out of it. I’m curious if this is the same. I looked at the part numbers and they appear to be the same number.
BW 1354 help
BW 1354 help
what does the other side look like of it. what year?
i am assuming you are building a doubler since the gear looks good
1990-1992 1354s got the same 4-pinion planetary as the 1350.
1993-2011 is 6-planet.
I recall there are differences in the shift collar as well (wider for the 6-planet setup).
Couldn't tell you whether the ring is the same though (never tore quite that far into one) so I guess I'm no help. lol
yeah, I have noticed all that. I have the correct rear case and found a planet gear off eBay. I'm still waiting on an email back from behemoth on the ring gear. I measured the older style gear (91) compared to the one that's in my newer 1354 (94) and it seems to be the same. I'm no machinist though, no idea if there is something blatantly obvious, I'm missing. picture of my current progress.
BW 1354 help
