- Sep 19, 2025
- Age
- 55
- Williamsburg
- State - Country
- VA - USA
- Other
- 2007 Volkawagen MK5 Rabbit 2.5
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- None yet ;-)
- Tire Size
- 265/75/16
- My credo
- Facta Non Verba
I'm adding a set of these to my parts list.It's also common to put a 1/2 inch spacer on the top stud before the washer and bushing go on. This puts the 1/2 inch back in the shock to add to its length.
Easy enough to install and/or remove.
Generally lift keys are used on the '08 and later trucks because they were indexed for a lower factory ride height than the earlier trucks. From what I remember the 98-07 factory keys will go about as high as you can reliably take the factory suspension components without having other issues.
So factory 98-07 keys will equate to +/- 1.5" front lift on a 2011 before additional adjustments?The hex is clocked differently in the different sets of keys. The 2008 - 2011 keys sit the truck about 1.5" lower than the 1998 - 2007 ones do.
I may look into them instead of aftermarket "lift" keys.
I believe I have read the same thing about the 98-07 rear leaf block?
I may have to look into that swap as well.
I'm not a fan of shackle lifts, so I am planning on a 1.5" AAL.
Yes, I know I will need new/longer u-bolts.
