Slightly extended shocks- who makes them? 02 4wd
b3million
Forum Member
Nowhere
AL - USA
Other
B3000
Drive
I'm about to throw a 2" torsion key/shackle lift on my truck. I have the tools, pinion shims, the actual kit, and everything else ready to go. However, I've seen that adding longer front shocks is recommended. I've also heard that the SLA suspension has a weird lower mount that makes finding longer shocks for the truck quite hard.
So, two things:
1. What are some good options? My truck has KYB monomax shocks right now from the PO.
2. Are their adapters or something similar to get around the mounting problem?
I'd like a set of bilsteins, but their corporate website only lists the b6 4600's (stock ride height) as options for my trucks. I have no idea if the longer shocks they offer, including the 5126 which comes in a wide range of length options, will even bolt to the truck. What can be done about this issue? Advice is welcomed and appreciated.
I call it a chicken leg. The bottom of the 4wd shocks have a leg on the bottom that is necessary to clear the outboard CV joints.
They say these are extended... but i have no experience with them.
TORCH Front Shocks https://www.amazon.com/dp/B0D2J4SGVV?tag=959media-20
It's also common to put a 1/2 inch spacer on the top stud before the washer and bushing go on. This puts the 1/2 inch back in the shock to add to its length.
I have KYB Mono Max shocks with no spacer and I have my bars turned up a bit. My rough country lift keys only came with one spacer when I was in there doing it originally. I'll make a pair to go in when I put the big torsion bars in. I also like the KYBs... so I plan to keep them.
So, two things:
Seeing as you have an 02, I doubt that the lift keys will get you much that you couldn't achieve with the stock keys. Generally lift keys are used on the '08 and later trucks because they were indexed for a lower factory ride height than the earlier trucks. From what I remember the 98-07 factory keys will go about as high as you can reliably take the factory suspension components without having other issues.
At one point I had the factory keys on my '99 cranked up to run 32x11.5. Can't tell you lift a number, I didn't do before and after measurements. They fit fine and truck rode and handled fine, went back smaller when they wore out in an effort to regain some power and gas mileage (still had the 4.0L OHV V6 then). Anyhow, while I was at that height I was running stock length Bilstein shocks with spacers on the stud as @Uncle Gump mentioned, as well as some between the bottom mount and the control arm. Still running the same shocks in "mildly lowered" stance with the spacers removed.
One misconception is that because the lift kit is listed as 2", that you need a 2" longer shock. Due to the shock being mounted inboard of the tire, that actually isn;t the case. You might need half that (or less) length at the shock to match the suspension changes. Just how a lever works. I'm not going to try to guess at the math to give an accurate number. Also the shocks on these generally have more travel range than what the truck can achieve, so it doesn't take a lot of spacer to keep it in it's happy range.
On my 99 I used nuts for my spacers. For the top I selected a nut that was a slip fit over the stud and probably 3/4" - 1" thick, then dropped it on the stud before installing at the top. At the bottom I grabbed longer grade 8 mounting hardware from ace, I sandwiched the mounting bar between the bolt and a nut, dropped that through the mounting holes, and installed a lock nut from the bottom. Guestimating I had 1" to 1.25" worth of spacer. I ran that for years and 10s of thousands of miles with no problems, and no premature wear on the shocks.
FWIW, when it was raised I was running Explorer leafs, lift block deleted, and with lift shackles. That would be about the same as your stock springs with factory lift blocks and a lift shackle. I was still running stock shocks in the rear, no spacers or anything rquired and no issues. They weren't Bilsteins, never got around to ordering a set for the rear, but no premature wear from running with the lift.
My set didn’t come with spacers. Are they necessary or just nice to have?
Sweet. Already have the keys, so I might as well put them on.
That or I return what i have and then buy the shackles. I’d probably get about a hundred bucks back for doing that.
That sounds good. I’ll look around my local hardware stores for nuts/bolts to use.
I'm not positive about the keys, only what I'm thinking based on what I've read and past experience with stock keys on mine. Like you said, you've got them, doesn't hurt to give them a try.
I think if I were in that position, I'd experiment a little. Adjust things how you like with stock keys, let it settle in and take some measurements. Count number of turns on the adjuster bolt when removing. Compare both sets of keys while they are removed. Change keys and set adjuster bolts back to same setting and then take measurements again. See how much lift you actually get from the same adjustment, or how many fewer turns it takes to achieve same height. See if you run into any other suspension/binding issues before maxing out the new keys. Just play around with settings and adjustments and compare results.
Not suggesting that you do that, just something I think I'd be tempted to do.
I’ve been playing around with torsion bar keys, I had a couple t-bar stubs but they seem to have wandered off somewhere and I haven’t quite figured out how best to set them to get somewhat accurate pictures but it appears that the 98-07 keys have slightly more lift than a 98 Explorer key (at least the v-8 AWD) and the 08-11 keys are a good bit lower than both. Not sure what it equates to on the truck yet though.
The hex is clocked differently in the different sets of keys. The 2008 - 2011 keys sit the truck about 1.5" lower than the 1998 - 2007 ones do.
I can't speak on the Explorer keys and I never tried aftermarket ones.
I know this, I was more speaking that the Explorer keys appeared to be a sort of intermediate, which might be interesting to the Explorer crowd
Rancho makes extended front shocks for a lift. I had to buy some for my truck when I bought it. The previous owner had the keys cranked up to the max with regular length rancho shocks on it and it had terrible bump steer. When I took the front shocks out the shock shafts had come in threaded and popped right out of the shock bodies lol.
Rancho makes extended front shocks for a lift. I had to buy some for my truck when I bought it. The previous owner had the keys cranked up to the max with regular length rancho shocks on it and it had terrible bump steer. When I took the front shocks out the shock shafts had come in threaded and popped right out of the shock bodies lol.View attachment 135318
Bilstein does too. Last I looked, finding out which ones were the right ones was not clear. Thus why I have Ranchos instead of Bilsteins.
Same exact reason I have Rancho too lol! I would have preferred Bilstein they have better reviews.
I hav 2" shackle lift on the rear and 2" coil spring lift on the front (2whl drive) with rancho shocks all around and I hate them
I hav some 2018 jeep wrangler shocks that are gonna go on next
10 or 12 bulging herniated disc's one ruptured and 2014 Ford something or other seats welded in and the Ranchos are beating me to death. Not bottoming out or hitting anything just way too much too tight
really?
i think you could be hitting limits with the big coils.
shock extenders can get ya by depending on situation. if it helps then buying shock may be ideal.
I ran those shock stem spacers with explorer coils, and F150 spacers On stock ttb. Just make sure you can’t bottom out the shock with inches of travel to go, that would likely ruin some things.
