Wheel Speed Sensor Struggles
ShyTown
Forum Member
Chicago
IL - USA
Vehicle
Drive
Hi all, first post here but I’ve been using the site quite a bit to get my ‘95 back in fighting shape. Such a great resource.
Anyway, I have a code indicating a bad wheel speed sensor. The old one was stuck in there so I had to pound it out with a punch. This seems to be pretty common. No big deal.
However, the new sensor is just slightly too big to fit. It was close enough that I thought I could pound it back in with a piece of wood and a hammer. Even tried freezing the new sensor to see if it would shrink up just a little. Too damn big. Now the new sensor is busted too.
Are they always this much trouble to get back in there? It was a cheap part, maybe I need to splurge on a quality one?
Thanks!
Yeah, you’re probably right. Thought I had it clean but I’ll try something more aggressive in there. Thank you
I agree with PJ. Clean out the hole. Wire bore brush on a drill or even use some fine sandpaper.
I've seen the sandpaper thing done on those. Perhaps a Dremel bit with a sandpaper barrel would be small enough to work? I've seen people use something to hold a strip of emery cloth but the holding method or type of holder being used is escaping me at the moment.
I like the dremel concept
I think I used a brake cylinder hone on mine.
You can try bubba-honing it; slip a skinny strip of sandpaper into the legs of big cotter pin, chuck the head of the cotter pin into a drill.
Wrap the sandpaper strip around the pin, into a coil, and then go to town. Low speed works best, and pick the paper grit based on how aggressive you want to be on the victim part.
I know, that's shade-tree as hell, but it works.
I wouldn’t be afraid of running an appropriate sized drill bit through there even. It’s not a part that requires a press fit. I usually use some grease on reassembly to help keep the rust gremlins at bay.
We have a piece of all thread with a slot cut in one end using a cut off wheel for cleaning nozzle bodies at work. Chuck it up in the drill and fold a piece of emery cloth or sandpaper double to squeeze into the slot. Very similar to the cotter pin above. Slightly more centered.
