Porous block or tiny crack?
pacstud
Forum Member
Grand Island
NE - USA
Vehicle
Drive
2.5 (4 Cylinder)
So... Not freeze plugs, not head gasket...pin prick leak from the block! I'll try to get pics but I put dye in and the ran a pressure test. It held the pressure but after wiping down the block I saw the tiniest pin prick leak. About 4-5 inches aft of the freeze plug on the passenger side and a few inches lower. Might be a crack, but if it is it's tiny. Ah, 360k miles but perhaps her race is run.
EDIT: lol, so then I find a nice used 1998 green ford ranger 2wd right down the road. It's a 3.0 so I guess I'll enter the timing cover gasket club. 195k for $3,000 though? I sense a haggle in my future.
If you like the truck and it's otherwise in good shape, it might be worth trying some Bars Leaks in it before giving up. It would be hard to justify a major repair at that mileage.
Tell me if this makes sense:
I'm going to flush just my radiator and pull the thermostat.
I'm going to fill with distilled water and some bars (copper).
I'm going to follow directions.
Then? Do I use a complete flush? Just the radiator from time to time? Do I leave it in?
I can wait to put the thermostat back in until it's going to get cold.
fwiw my heater core is tip top, no leaks blows hot.
But doors and windows. A 1998 Ranger that's identical just posted for 3k, but it has the 3.0 and is an automatic. I may just get that after I patch and sell my current girl. Sad though.
Bypass the heater before adding the stop leak just in case and don't use a chemical flush afterwards.
OK, I wasn't going to use chemicals, just distilled water. As for bypassing, it's too late (I did it last night) but the directions say to crank the heater for the whole 15 minutes. I did think if needed I could just flush the core, separate from the cooling system flush (same for rad) so that the copper in there doesn't just accrue elsewhere.
Back flush the heater. Hopefully that will clear out whatever got in there. It is generally recommended to switch the heater lines everytime the coolant is changed anyway, for the same reason. Flushing out any gunk that may have gotten or built up in the heater core.
