Lowered My `23 XL 2WD For Mountain Twisties
CurveRider
Forum Member
Maryville
TN - USA
Vehicle
Drive
2.3 EcoBoost
2"/4"
255x65R17
The happiness of your life depends upon the quality of your thoughts. – Marcus Aurelius
I live a few minutes from the 318 curves of the "Tail of the Dragon", Hwy. 129 @ Deals Gap in E. TN which I drive often. Since a lower center of gravity helps handling, a Belltech axle-flip kit was installed which lowers my Ranger 2" front and 4" rear. The kit fit just fine but created very annoying vibrations from 15-35 MPH due to excessive pinion-up angle. So, I got an angle-measuring app for my iPhone and measured the tranny and pinion angles (they should be very close to parallel for minimal vibes). The pinion had gained 6 degrees up-angle from lowering so I ordered Belltech 6 degree spacers and installed them between the axle and springs which corrected the angle and eliminated the vibes. The Ranger rides smoothly now and handles much better...! I am so happy with the results that I ordered a Livernois ECU tune. :)
Cheers from the Smoky Mountains.
Before:
After:
On the Dragon:
On the Dragon:
On the Dragon:
I like it...
and...
It's not a more door.
Its the real life version of the one ai made for me.
Hellwig makes a rear sway bar for us but 1) It's not cheap and 2) I'd check with them first to see if it will work with the lowering kit.
I have a super pro 24mm rear sway bar. Makes a huge difference
Hellwig makes a rear sway bar for us but I'd check with them first to see if it will work with the lowering kit.
Good point. Thanks.
My tail of the dragon pic
Good point. Thanks.
I might have liked one myself when I was towing a rented camper two weeks ago but I might never do it again. Also my truck just hit 100k so I'm thinking about getting a new one in the spring after my new knees are paid off.
Thanks for your generous comments folks!
Now I'm going to try to load a Livernois tune with their "My Calibrator" device. I'm a tad nervous about it due to the *MANY* requirements and cautions on their instruction sheet. If I brick my ECU, I'll never live it down with my wife...:oops::p
Man that things gonna be a blast to drive after the tune.
