- Jun 21, 2010
Thanks, I should have clarified my cooling setup. The truck has the OEM style radiator with only the auto transmission cooler lines running through the radiator. I was hoping the chocolate colored water might be cooked tranny fluid since a radiator replacement is pretty simple.
It looks like the consensus is the brown goop is indeed engine oil and most likely due to a blown head gasket. Not sure what caused it though. I've owned the truck since 2006 with 28K miles and have never had any cooling problems. I guess 190K miles with no problems is pretty good and maybe the head gasket just wore out.
So here's my last few questions before I tackle the head gasket replacement :
- Before I dive into this project is there any chance this oily mess in my coolant could be caused by a bad timing chain cover gasket ? Just want to be certain there isn't some kind of test I could perform. I'd hate to repalce the head gaskets and find out it was the timing chain cover.
- Fel-Pro sells a complete head gasket kit with all the additional gaskets and seals as well as a head bolt kit. What's everyone's opinion of Fel-Pro or is there another preferred gasket brand ?
- Lastly, any advice on how to get those rusty exhaust manifold bolts off as gracefully as possible ? They've never been off since the factory and I hear they tend to break off pretty easily.
Thanks again for everyone's help !!
Jerry
Jerry
