Transmission mount
Papaw2eleven
Indiana
I have a 2000 Ranger with a 289 engine swap. I installed a M5ODr2 transmission, my problem is the transmission mount sits about 1/2" behind the transmission crossmember. Any suggestions would be appreciated.
Can you weld? Or know a local shop that does welding? Have a plate welded on the crossmember to extend it back the 1/2 inch.
Elongate the holes on frame, cross member ends and middle. Should only have to file slightly over 1/8" on each hole.
