- Aug 7, 2007
I removed my rear driveshaft in order to try a "coast test" (coast downhill with the front driveshaft immobilized and the rear driveshaft gone in order to rule out the transmission and transfer case for a noise I've been chasing). As I put it back on, I peeked in the 1991 Chassis Service Manual for torque specs.
The rear flange spec was as expected -- 70-85 ft-lbs if I remember right.
The front flange spec was ridiculous. 12-16 ft-lbs.
This was specifically for an Explorer rear driveshaft. I cranked it to 65 ft-lbs, on the low side of the Ranger spec. The transfer case flange appears identical to that on almost every other 4x4 RBV, heavily reinforced, and with the exact same M12x1.75 bolts as the rear flange. I don't see how it would distort.
WTF?
WTF?
