2.9 Cam and Lifters
Gunfighter97
Forum Member
Idaho, USA
I've got my junkyard engine torn down to a short block and began work on the rear main seal, cleaning up the pickup tube/pump, and just managed to clean enough varnish out to pull the first lifter. Immediately could tell it was cupped. Im running some erands to among other things, grab a can of spray that will better aniahlate varnish, but am curious what yall would do. I don't want to remove the crank if I dont have to, but I think it might be wise at this point to pull the cam out for a looksee.
When I pulled my engine during a swap, I pulled the pan and took a main bearing cap off and a rod cap off just to have a look. They looked good and I knew the history of the engine, so new gaskets and cylinder heads, and it has been running ever since. Didn't have but one pesky oil leak around the front of the engine. Found out you must put rtv behind the large washer that goes behind the crankshaft bolt. Oil will migrate up past the key and the keyway and make it's way around the washer and sling out all over the front of the engine. Not a bad leak, but one of those small aggravating leaks.
P.S. Make sure your freeze plugs look like new. Mine were rusted and there is one inbetween the back of the engine and the bellhousing that you can't get to except with the engine out. I would replace them all while you have the engine out. And make sure the timing chain looks like new.
Cam is wiped :shout:
Probably why it was in the junkyard. Every single lifter was dished, bar one and it was flat and non rotational. Lobes dont look great. As I type Im going to measure with my dial caliper. . . The one lobe from the one non dished lifter is 35 thou taller than most of the rest, there are a few 15 thou shorter at closest.
