1994 Fender Trim Color
Salt Lake City
UT - USA
Vehicle
Drive
How do I find the color code for my flared fenders? They are silver in color with the mocha frost on the rest of my 1994 Ranger truck. The fender flares need some fresh paint.
I will include a photo of the door sticker. I tried searching the forum for info but maybe I don’t know what I’m doing since I am new here.
Thanks
Also, my mirrors need paint. My question is regarding the color, were they black or was it a dark gray?
I believe your color code is MB as listed under the word "EXTERIOR."
I just went thru this so let me check mine...back in a sec to edit
EDIT: Nope, my bad. Your color code is DD.
Here's an image of mine: My code is YC, above the word: EXTERIOR. I have a 94 as well.
Have you tried any of the newer plastic restore products that have these days?
Those flares weren't painted... the mirrors were black i believe.
The flares look painted to me, if you examine the photos you will see that the paint has flaked off at the top showing a much lighter color, similar to my mirrors.
I know that the code DD is the mocha frost. I was wondering if there was further info like the 56 or EP.
It has been a great truck that I have had for many years now and it just needs a little sprucing up to make it shine. It deserves it.
If it were me, I'd pull the fender flares and mirrors off (or mask around them) and paint charcoal gray (probably the original color) or black. Using satin or eggshell not a gloss. That bumper strip in the middle of the door would be a little harder. Is it rubber?
Well they could have been painted at some point... but they weren't from the factory.
I don't think I have ever seen painted factory flares on a third gen now that I think of it.
As the original owner of my '94, I can say that the factory flares do have a gray coating on them (I think it might've been called Argent Gray, if I remember correct, although the later ones ('95-'97) had a very slight reddish or pinkish hue when put next to the older ('93-'94) ones).
If that isn't paint that is on them, it certainly has the appearance of paint. Underneath that coating the plastic material is almost white.
With the right prep work I see no reason why they couldn't be (re?)painted.
Where did you locate the argent gray paint? I went to an automotive paint store and they were looking, examining, searching for a color match. What they sold me appears to be lighter but I will try it and see.
My fender flares are factory because I did remove one and it has the ford emblem and part number on the inside.
I didn't (the paint on mine were all still fine).
Since they aren't color-matched with the body paint, I doubt any slight difference in shade would be noticeable (IIRC, the bumpers & (steel) wheels on some non-XLT trucks were painted that same gray color too).
