No Blinkers or Reverse Lights
1stGenPOS
Pahrump
NV - USA
Vehicle
Drive
I have an 84 ranger with 2.3 Lima and a 4 speed manual. I recently replaced the starter relay and now my blinkers and reverse lights dont work. All the other lights do still work. I already replaced the flashers, and the hazards still work. Any help is greatly appreciated
Check for power at fuse #5, which feeds the turns (hazards have their own second flasher). See the diagram below.
Originally, there were several fusible links at the starter relay battery cable; you may want check that all are still there, and maybe clean up some things. You really need a fuse or fusible link on each of the smaller feed wires at their power source.
And please fix that battery ground cable- crimp or solder the right size ring cable onto the cable. Shaving strands makes heat, that starts the copper rotting and the connection WILL fail early.
Long shot issue- check that the ignition switch is not starting to come apart.
I like that you're cleaning up the wiring; but, the devil is in the details. (y)
Good luck!
Why don't I see any fusible links at the starter relay under the battery positive cable?
look
because those been gone since back in 57
Good luck!
Thank you. I will work on it tomorrow and update this post 🤙
That ground wire is effectively way smaller now. I'm surprised it starts...
I just bought a new terminal that should be big enough. I haven’t had the chance to throw it on yet
