What Fittings Fit the 2.9 Fuel Rail?
Resident_Ranger
Just as the title says, what are the two fittings that fit the fuel rail and regulator on the 2.9? The two braided line on mine went bad trying to get them removed.
Ford made their own high pressure connector for the fuel and AC systems. You can only buy the male ends new.
Dorman 800-130 & 800-131
LMR LRS-9964B-K has the female fittings as a kit but this is the only place I have seen them
That's good to know, I was thinking about making that side, but maybe I'll just buy those. But I was wondering about the side that threads into the regulator and the metal tube coming off the fuel rail.
That is something I can't figure out at the moment. Its something like a M14 with a weird taper that no one makes iirc
So, both of the quick connect ends are available in -6AN fittings. Male and female in both sizes. I don’t have part numbers handy though.
The tapered threaded fittings at the rail I’ve been meaning to try and figure out a solution for but I’ve been so backed up and blown out on projects and problems this year that I haven’t had time to mess with it.
I am going to say this, if the braided lines at the rail are bad, what is the condition of the rest of the fuel lines? I just replaced all of the fuel lines up to the braided ones at the rail in my Choptop because the braided lines were fine but there was about 6 leaks in the factory nylon lines…
Dude I need those part numbers I'm doing the exact same thing cause the nylons rotted out.
I’m not going to have time to go searching for them until at least next Wednesday. I bought all of my AN stuff from Summit Racing. If I was doing all the way to the fuel rail, I’d probably skip the quick connects and just put an AN union near the rail.
That's my plan thanks time to go to summit do you happen to know the sizes I need to look for cause I messed up before and got the wrong sizes once already
I used -6 PTFE braided line, it’s resistant to ethanol unlike most rubber line. I needed 3/8” and 5/16” EFI connectors for the fuel pump and filter, don’t remember exactly what was used where offhand. Bout the best I can do at the moment, I’m about to be gone to my buddies place to deal with problems
So I did a little measuring today. I didn't figure out anything more than measurements so I thought I would share so far. These probably aren't perfect due to eyeing the half way point to cut. But it should help us figure out what to use. I attached the regulator fitting and the rail fitting.
  • What Fittings Fit the 2.9 Fuel Rail?
Sae or metric?
