98-11 torsion bar suspension lowering arms
lil_Blue_Ford
Cut & Weld
⭐Supporting Member
TRS 25th Anniversary
Butler
PA - USA
Vehicle
4”
I have reached out to RicksRangerz, Michigan Metal Works and Illusive Fabrication so far for these. I’d like to encourage anyone here at all interested in lowering arms for these trucks to reach out as well, it only takes a couple minutes to send them a message. It would be nice to see someone manufacturing these lowering arms again, but one or two people probably isn’t going to motivate them, so I’m posting and asking for help messaging these companies. I’m sure if they get enough responses they will be more inclined to help the Ranger/Explorer community.
So far Rick’s got back to me saying that it’s in their plans, but they have no timetable yet as they want to see how the 2wd arms do. I get that, but I can’t wait indefinitely as I already waited most of this year with promises they are coming. I think they need a push from the community.
So, update time…
Nothing heard from Illusive Fab. Absolute silence.
Michigan Metal Works said they do not sell them and apparently don’t plan to, but if I give them all the measurements they can quote me for making custom pieces but they will have to buy stock arms and make a jig which sounds like I’d get to pay for. If a jig has to be made and I have to do all the math, I might as well just make the jig myself and be done with it. I’ve considered it, but I really don’t have the time with everything else I have to do right now.
Rick’s Rangers got back to me on my response about being on a time crunch and said he (Rick) ordered stock arms and will be working on starting to make the adjustable lowering arms for a 4x4. I was told to check in next week on progress. This sounds pretty promising… definitely sounds like he’s willing to help and is willing to go the extra mile.
Still crickets from Illusive Fab. Guess they are too busy to be interested in my money.
I haven’t responded to MMW’s lukewarm response.
RicksRangers says they can make them and are currently working on getting parts to build a jig and getting started on it. Guess I better get cracking on getting everything done on my Ranger… so, apparently coming soon, the wait for lowering arms may be over with…
First set is at the powder coater according to Rick…
Most interesting. Keep us posted
Saw a post on FB that the first set is done. I’m gonna reach out Monday if I don’t hear from him sooner…
Let us know what he says and how they fit if you get them. Even though I think I'm changing directions and lifting mine, I still think I might get a set to store just in case.
Perhaps some of you old timers can help me with this. I have a two thousand free Ford Ranger Edge. I did not like the way it handled at highway speed. I felt that the front end dipped and plowed too much under emergency braking and turning. So I removed the two inch lift blocks in the rear and replaced them with ones. I cranked down the stock torsion keys on the front about as far as they would go...about ahalf inch, maye five eighths.
The handling is much improved. The whole truck is more or less level, the front end is slightly lower. I believe that the handling would be better if the front were even a little lower. I could possibly buy different keys OR maybe now I could get lowering arms. Any advice?
Do the arms. That will be my next step on mine. I lowered my torsion bars till the bolt fell out and flipped the back and pulled the two spacers out. Mine is as far as its going without those arms
Oh I’m fully intending on getting a set and seeing how well they work out. I’m sticking with the lowered plan so I either need these or I need to make my own. I did play around with making my own but I never got past the scratch paper stage. Just not enough of me to go around right now. These may be my answer.
The lower you can get your center of gravity, the better it will stay planted, so lowering makes sense along with front and rear sway bars and traction bars. All works together. I was able to push my green Ranger hard enough with current mods to tell that tire squish was becoming a noticeable factor. Hence my current plan of 18” Explorer rims and I’ve been looking at tires that work out to be like a 29”-ish diameter and between 9.5-11” wide.
I also have a set of the 07-11 T-bar keys to see what that does for me. I had my adjusters backed out about as far as possible and my front end was still a good inch or so too high. I’d love to do coilovers but I don’t have the budget. The other thing I encountered was that the upper ball joint was about maxed out with the T-bars as low as I could get and my camber was out of adjustable bolt limits, so the upper arms need to be longer the lower you go and the ball joint needs to be re-aligned. I’m not sure yet if the lower ball joint will need adjustment, but for me that’s just a cut and some welding with plates to fix.
The arms are necessary when you get to a certain point with lowering.
You may have noticed already, but FYI the torsion bar arms are now listed on his website. They were not available to buy yet when I saw it the other day, but actually being listed is a big step forward IMO.
I have seen them, he hasn’t fixed the price yet. I also have things set up to get the second pair (first went to one of his buddies). I’ll be placing my order later this month. He’s still waiting on some parts for them last I heard and he’s waiting on feedback from the first production ones. I’m intending on thrashing on my Ranger this week. Next week I might have to do some other stuff, so we’ll see how things go. I’d like to have this thing back on the road before the end of the month, but I have a ton to do yet… gonna give it a heck of a try anyway, everyone been told to leave me alone for a bit so I can thrash.
