- Sep 15, 2025
- USA
- State - Country
- N/A
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
First time post. I’ve read through the forums and tried to get as much info as possible, but I have a few symptoms that don’t seem to match other posters.
History: past two weeks, engine has been having a rough/low idle when unloaded, but turning on the AC increases RPMs and the rough idle goes away. In the past 3 months, I replaced IAC valve, EGR, and DPFE for a code 335 and 327.
This morning, engine turns over, starts then dies. Second attempt engine started and ran fine. Drove into work no issues. Second start today, engine starts then dies immediately. After engine cranks over/starts, engine stalls within 1 second then the dash lights shut off and the battery voltage drops to 0 (bad relay?). Attempted to start several times and same result.
Battery is charged, starter is working as it should, and engine will start running so I believe it’s an electrical issue cutting power as soon as the starter is off. I hear the fuel pump turning on when I turn the key on, engine codes are 335 EGR out of range and 157 MAF signal is low or grounded.
Whenever I can get a tow/back to the garage, I plan to test MAF, fuel pump relay, and fuel pump. Any tips for diagnostic or other things to check? The main symptom I’m seeing that is different from other posts is the dash lights shutting off when the engine dies with the key still in the ignition. I’m thinking there may be an electrical issue cutting power to the system once the engine has cranked over. Thank you for your time.
