2.3L ('83-'97) 2.5 swap problems
Denver
NC - USA
Vehicle
Drive
2.5 (4 Cylinder)
Hey everyone, i have a 1996 ranger 5 speed i bought with a bad engine. I built a 2.5 engine, i have ported the head, and milled it .030. I am having a problem with a rich code and it will stall on decel untill it gets into closed loop. New maf, coils, 02 sensors, fuel pump,PO deleted cat (i will replace once it runs with no codes but it is not throwing a cat code). I drive this truck daily and the plugs read find. I am at a loss for this rich code. Thank you all
So what are the fuel trims doing when driving at different speeds and loads? There's two ways of interpreting the codes, is it running too rich or adding too much fuel? Watch the short term and long term fuel trim values, I use Torque Lite with the cheap blue things with both on gauges showing high and low values on the same tab. Pay attention to both at no load idle and say 2k rpm while driving in each gear at steady speeds. Since I'm not sure if it's adding too much fuel or taking away too much fuel it's hard to recommend what you might need to do.
One dumb thought is fuel injectors, are you using the ones from the 2.3L or 2.5L? They're different not to mention a '96 is set up for lower fuel pressure and a return and regulator on the fuel rail and the 2.5 is returnless.
I have new 1996 2.3 injectors in it, my brother took my code reader that let me check fuel trims and left it in the car he scraped... I will buy a new one but the good ones are just expensive. Everything like the manifold and sensors are off the 1996. Thank you
Assuming you have an android phone just get one of THESE and download the torque lite app, it's all I've got and it does decent.
I got a reader, now i am more confused, the fuel trim long term is at -17 ond short term is calling for -8 to -15, it keeps leaning out and changes the timing. The timing start at 10 or so and works it way up to 25 at the same time it is leaning out; when it get to 25 it has a closed loop fault and goes into open loop. Tps reads good, iac seems fine, i put another 02 up stream in it yesterday, and put a different maf sensor in. I am at a loss thank you
What about fuel pressure? If the vacuum line on the regulator isn't hooked up (it's easy to miss, I've done it) the pressure would be high and it would be taking out fuel. A vacuum leak would be the other way.
I tried to check it but the AutoZone lend a tool gauge is was broken, everything is hooked up, i pulled the line off and capped everything and it still did the same thing. But i will go to a different auto parts store and try again today after work.
Apparently you cant use autozone fuel pressure gauges on these fords, the adapter seals everything off. I changed the fuel pressure regulator, same results.
Turns out the new fuel injectors were bad for anyone in the future
I wondered about that... cant trust anything anymore
I wanted to add that my mass airflow sensor was giving me problems still it ended up being that the can that it is in did not align with the opening causing weird stuff to happen I replaced the can and it fixed all of the fuel trims. Just seemed like a weird problem maybe somebody in the future will be helped by this.
2.5 swap problems
That's a weird alignment there...
