2.3L ('02-'11) no engine oil on dipstick when buying used 2002 i4 ranger
youngbuckwithapickuptruck
california
2.5 (4 Cylinder)
stock
im looking at purchasing a 2002 ranger.
1st owner had it to 160,000mi and i will assume maintained it since there is a carfax report with it, first owner, etc.
no info on 2nd owner but
1. they hackjob the wiring for a third light on a campershell - 3rd owner paid to have that fixed
2. they must have not changed the oil for 20,000mi from 2018 to 2023 becuase mechanic report stated "no oil on dipstick"
is this a red flag for a no good engine?
i hear lack of oil change ruins timingCHAIN.
will "timing-CHAIN job" resolve the issue?
also: third owner had truck for 2 years and only put 2k miles, is that also a red flag on used vehicles? do people sit on a truck then resell it when its a lemon? dude says he didnt use it becuase he just had a kid. also they live on an island.
i know 2001-2003 i4 also has issues with the intake manifold, should i just avoid this truck?
*EDIT* im literally buying this truck to jump my mpg from 25 to 30.
i currently have a 350,000mi 2.5 ranger ...same color, lol
*edited timingbelt to timingCHAIN*
Dirty oil can ruin a timing CHAIN, belts are usually dry.
Always go with your initial gut instinct. Yours seems to be telling you to pass on the truck.. and I'd agree.
my instict is telling me that no used truck will be a safe bet and that any 1previous owner grandpa truck will be hawked by resellers way faster than i could ever catch the ad and snag it
also i wouldnt hesistate to throw a refurbished engine in this truck becuase interior and exterior shows lack of abuse as a work truck
pull the plugs to see if one is fouled with oil. do not be concerned with oil in the plug wells, it's a gasket fix. just clean it out before removing plugs.
during its later miles my 2.3 duratec lost compression on just 1 cylinder and had massive oil consumption, on that cylinder only.
compression was down to 80, rings were not sealing.
the other 3, and the bearings, cam, were still perfect.
the Duratecs have a good oil return system. even when quite low there is enough in the sump for circulation.
my chains were still factory at 366,000+ miles
I've never messed with a carfax... ignorance is bliss. :icon_twisted:
I would say that interval is far less than ideal. On a old truck... if it runs nice and quiet I wouldn't worry so much.
It could be leveraged to help the price.
Yeah, you could buy with with the intent to pop a motor in it... but at that point you could probably find a cheaper truck that actually has a bad motor to start with.
I might be tempted to crawl underneath and drain a little oil and see if it's sparkly...
My wife's Camry is nearly weekly to the point where there's no oil on the dipstick... how that thing still goes fine is beyond me, I shouldn't say anything... I have a parts car with half the miles on it and likely less abuse to steal the engine from just not the time to swap the engine, I'll get to it this winter.
That said, maybe add a quart and see how low it really is if you don't want to see if it's sparkly... those engines are pretty good, I was torn when I went looking for one when I got my '97 but I just know so much more about the Lima's and TIB... Price definitely makes a difference, I was able to look past things when I picked up my '97 for $450...
how do i approach him about getting a cold start with the truck? i know sellers are hesitant to meet at their homes. same thing with popping open a spark plug on each cylinder.
i suppose i could
ask him to take it to a local
shop for vehicle inspection and pay the $200. should i ask them to check timing belt?
does a timing chain rattle when the engine is warmed up? is it louder at idle and can it be heard when driving down the hwy?
just thought i would add, dude dropped 2k on overhual at a shop when he first bought the truck. they "de-carbon treatment" the motor when they found oil low. no mention of just how much oil actually came out when they did the oil change.
ive had my 2.5l lima for almost 20 years and i want the mpg gains of the 2.3duratech
Is your present truck in good shape? If so it'll take a long time to offset the price of this truck with gas savings even if the engine isn't toast. If the owner didn't even check the oil he didn't do ant maintenance, either.
2nd owner *i assume* did not do maintenance between 2020 and 2023
also at $5/gal the truck would save me about $3,500 over the next 100,000mi with an mpg jump from 25 to 30mpg
I JUST TEST DROVE TRUCK
it aint nice, lol
Cold start it made a loud dull "TUK TUK TUK" noise until engine reached about 50 or 60*C and then the noise stopped. is this the "faulty flaps" on intake manifold or "timing chain slap"?
Gf said she heard the engine "skipping" as if a cylinder was out or something, i didnt hear it.
Very rough idle, truck is shakey when driving.
Transmission is very loud clunk when shifting -mine dont do that-
suspension and interior looked immaculate.
Tire humming/shaking during wide turns at speed but he said he had wheel bearings replaced 2years/2000miles ago and theres no weird wear patterns on the tires.
And.... FRESH OIL EVERYWHERE.
looks to be lots of fresh oil -i would guess- from "rear main seal" between engine and transmission.
And then there is crusted oil all over the top/middle of engine.
And then tons of shiny fresh oil leaking from this pulley... and the rest of the pulleys. i cant fine a serpentine belt diagram that would tell which pulley this is.
I did not check spark plugs. i told him i would consult my internet friends and if im still interested, I would like to check the spark plugs.
i suppose i should run from it.
also yesterday i was hanging out with these two kids i know and havent seen for six months. the boy just bought an immaculate 2004 4cyl mt ranger when i was hanging out with him in the desert those six months back. and the girl just bought a clean perfect 2000 4cyl mt ranger, waaaahhhhhhh, lol
man... ive been seeing a lot of old people driving a lot of nice rangers on this island. in fact when we first parked and got out the car this geriatric old lady comes up to us and talks to us about our dog and just keeps talking and talking and talking and then half an hour later she leaves the prking lot in a pristine mt 98-01 ranger, lol
the smooth pully with 3 bolts is the water pump.
the center pully with the belt facing out is an idler, it mounts to a stub on the front cover. it should have no access to any oil.
Tuk, Tuk until it's warmed up has me worried. I've never heard the bad flaps but temperature related noise is usually worn metal someplace.
a 2002 should have an aluminum valve cover, not the later plastic so upper leaks may be just a gasket.
something turn key and ready to drive? solid no.
want a handyman special and willing/capable to do some drivetrain work? go for it
I'm in the rust belt, we're willing to settle for any drivetrain issue if we can get a pristine body.
oh, by the way, the oil filter is up-side-down :icon_thumby:
also i noticed the coolant runs hot at about 105 - 110*C and sometimes spiked up to 120*C
temp gauge issue?
