- Jun 28, 2025
- North Carolina
Hello all,
This is my first post here-- I'm not super literate when it comes to auto stuff, so forgive me if any of these questions are stupid or self-evident.
I have a 98 V6 Ranger that I bought from my grandmother and, importantly, it came with one key. I never had a copy made and now I've lost my only key. I called a locksmith out, they found that the ignition had been changed out in the past and the wafers were rubbed down, so they convinced me to let them drill it out. Okay, fine, maybe my first mistake but I just want to get the thing running. But the locksmith then tried to use a chipless key (though i told him I believed it needed a transponder). Needless to say, after he cut the new key, it didn't work. He tried to tell me it was just an issue with the starter relay or something and I said this seemed like the PATS system, which I understand some 1998's have. He also set off the alarm while doing this and the horn is honking like crazy. Now, the horn won't stop. I removed the negative terminal from the battery to shut it up before my neighbors kill me.
Anyway, he left with it unresolved, saying that the truck should be starting with the chipless key, telling me to check my starter and solenoid and whatever else. I did my research and everyone I asked at the local Ford dealers said no, this truck requires a programmed key. He comes back out, cuts a chipped key, we put the battery terminal on, it starts honking/flashing, and while it's honking he tries to connect to the PCM to program a key. He said his scanners could not communicate with the PCM system. Voltage was good, everything on his checklist up to the point of the PCM communicating looked fine. Am I correct to think that he will not be able to communicate with the PCM while the alarm is armed and sounding? I know that the cigar lighter is operated by the same fuse as the OBD port, and my cigar lighter worked right up to the point of me losing my key.
I'm sure there's relevant information I've left out, so I'll try to provide it to anyone who asks. I just want to get a key that will operate this truck again. Two days ago I didn't even know what a PCM was, and now I'm sitting here reading these forums trying to figure out what in the world is the issue. Any help would be appreciated. My next course of action might be to program a key fob to the truck to shut off the alarm, but 1) I'm not sure this will work and 2) I'm not sure I can do this without a programmed key.
Edit: Also, if this thread is in the wrong forum, just let me know where it fits best
