This is my experience having built hi performance engines for 30 years, so take its for what its worth.
7000 rpm is pretty doable for many stock crankshafts, Bracket drag racing well prepped cast crank with nice radius work and balancing will go about 300 passes before crack start showing up. Drag racing is the easiest because the stress is one way. In road racing or roundy round, cast cranks dont fair as well, decelerating can be much harder on part because once you chop the throttle and compression disappears the rotating assembly load doubles. Most engine blow when you get out of the throttle at the end of the run.
Connecting rods are a whole different story, I'm a Ford guy keep in mind but, Ford connecting rods always seem to be lacking somewhere. Bolt size, beam strength, cap rigidity, broached instead of spot faced for the rod bolt head, etc. etc. . The 2.8 rod is no exception, they are decent and for a nice 6000rpm build I think they do fine. But if I was going to to spin the engine they would be the first thing to go.
I using 52mm journal Subaru H beams in mine just because they are pretty close dimensionally. Rod length is the same. I like the 2mm smaller rod journal and 1mm smaller wrist pin. 3/8 ARP 2000 rod bolt is over kill to boot.
