- Apr 8, 2016
- 4.0 V6
- Total Lift
- 5"
- Tire Size
- 32x11.50
Selling my 1997 Ranger 4.0 5 Speed. I love this truck, too much else going on in life. It has long travel James Duff suspension with 4-5" of lift, Rancho shocks were installed in 2021 32x11.5x15 Mud Claw Tires with a little life left in them. Morana Racing built the long block for me about 9 yrs ago. It has the comp cams 422 cam in it, heavy duty timing chain, forged flat top pistons (stock compression), stage 3 heads, JBA Headers, Demon coil, Livewire plug wires, 24lb injectors, custom upper intake from 94 explorer(I think) that is modified to accept a 75mm throttle body (mustang model), custom linkage, 80mm Mass Air with AFE filter, probably some other stuff I forgot. A couple quirks with the performance are that the new intake had no EGR connection, I tried some bypass trick I found for the sensor. Also faults the rear O2 sensor, full 3" exhaust with a Dynomax muffler, it's loud. I never got a tune done for it because I only finished the intake manifold a year ago and was making sure I could actually do it. Main seals are leaky, I think there was a PCV issue at some point and caused that. I was planning to pull the trans this summer and do the rear main and also the slave cylinder since it would be apart, I've had to top off the clutch fluid here and there. Truck has 164,000 miles, engine less than 20,000. topper paint in rough shape, it doesn't necessarily need to go with the truck. roof and hood need some love with clear coat. There are 3 Yakima roof bars, one for the cab and 2 for the topper that can go with it. Also has James Duff front and rear receiver tube bumpers. There are tabs welded to the front for a tow bar, which will also go with it. Bucket seats from Explorer. I purchased the truck new, clean title. Probably a bunch more I'm forgetting overall, just message me. Have some videos of exhaust and engine running but it won't let me upload them. Colorado Springs.
