- Mar 12, 2019
- Age
- 21
- Buhl,ID
- 1986ish
- 2.9 V6
- Total Drop
- shot bushings?
- Tire Size
- 235/75/r15
- My credo
- To send it or not to send it, that is the question.
So i have a 1987 ford ranger stx 2.9, truck is new to me and only has 139k on it, just about everything is original on it. Ive been stumped by this issue because it has a very large surge at idle, randomly while cruising it seems to be cutting spark and if i give it full throttle the issue stops, ive replaced the 02 sensor thinking that it was that causing it but it had no effect, the map sensor i replaced with a known good one, has a new fuel filter, both pumps are new, brand new fuel tank because it had sat for awhile. The fuel pressure regulator is not leaking at it is sitting at spec for pressure. no vacuum leaks and the egr i blocked off to see if it was leaking and it isnt the tfi module i swapped with a test one that i have and had no effecti haven't pulled the ecm yet to check for water damage or blown capacitors yet but i will soon
