- Apr 27, 2025
- Harford county MD
So after finding pieces of the cassettes in the oil pan on my 4.0 sohc, I’m pulling the engine and doing it all.
Couple questions before I start on the parts.
I already bought a set of hydraulic tensioners from Cloyes anticipating trying them first to see if it calmed down my rattle. That was before I found pieces in the oil pan. Are the rest of the components from cloyes ok to use compared to Ford oem stuff? Is it worth doing all the chains and sprockets too will I’m at it? I’m at 160k.
I can imagine what all the parts strait from a ford would cost compared to the cheap kits I see on parts geek or amazon but I want to do it right and not cheap out. Has anyone seen the timing chain kits sold on ebay that are supposed to be ford oem? Even the packaging in the pictures say ford on them with ford part numbers. The kits are around 200 bucks.
how about the tools to time the engine with the new components. I’ve seen a used set of otc tools on ebay for around 200. Again it’s something I wouldn’t want to cheap out on but if the 70 dollar nock off kit will work I’d like to hear about it.
one last thing is deleting the balance shaft if mine has one. It’s a 2003 4x4 so I’m assuming it has one. Pros and cons on that?
I’ve been searching and reading as much as I can on here about this whole process. I’m confident in doing the job, I just want to Mach sure I use the right parts so I’m not pulling the engine again in 6 months.
thank you
thank you
