- Apr 29, 2025
- Houston, Tx
2000 Ford Ranger 2WD - 2.5 automatic - 94k original miles
Engine is surging up and down intermittently at idle once warm. While driving I get a major loss of power. At freeway speed the engine stutters and seems to jump out of gear, revs freely then rolls or slams back into gear. As of last night, it now dies when this happens. I was able to restart after a few attempts.
With each stumble or surge of the idle, the fuel pump relay clicks. Relay tested and good.
Parts replaced:
IACV (aftermarket and OEM)
new plugs. coils and wires (tested)
new MAF (aftermarket - I suspect this to be an issue. Should I buy Delphi)
injector 1 and 2 (had previous cylinder 1 misfire intermittently - code would come up the truck would idle poorly then it would clear itself automatically) NOTE: this all started after replacing the fuel injector 1. However, I have confirmed everything is put back together.
Battery is strong.
Alternator replaced.
Fuel pump (pressure reads 65psi at idle - stumbles down to 60 with each stutter or surge and kicks back to 65psi.)
Fuel pump relay
Fuel tank pressure sensor
TPS
EGR sensor
No CEL. CEL does flash occasionally when idle stumbles.
I am completely lost here. I am starting to think this is either the result of a Duralast MAF or a bad PCM. However, I have a hard time believing that it is the PCM. No visible damage and the truck starts every time no issues, unless of course it just died on the freeway. I have had constant issue with idle and drivability with this truck since purchasing 30k miles ago.
Any advice helps!
Parts replaced:
Battery is strong.
Fuel pump relay
TPS
EGR sensor
Any advice helps!
