- Oct 30, 2015
- St. Louis, MO
- My credo
- Well, that didn't work. Let's try something else!
I picked up this little lima 2.3 that came out of an industrial generator that purportedly had ~50 hours on it for $300. I was reasonably sure it wasn't different enough that it wouldn't work in a truck, so I took the chance. As far as I can tell, it was set up for gasoline, not LPG. It came with the intake and exhaust manifolds, an alternator, and the flywheel for the generator. I plan to use a standard Ranger exhaust manifold and a mustang d-port intake. I'll also use a rangers flywheel/clutch/pressure plate, of course. Is there anything that would prevent those plans from working out? Are there differences with the industrial engines that make them ill-suited for our trucks? I plan to use it in an 83. It looks like the mounts will bolt right up to me.
Any info is appreciated! Thanks!
This plate is on the side of the valve cover. Don't know if anyone can decode any of this stuff.
The generator intake with it's Zenith carb.
Generator intake with 1bbl Zenith carb
Generator exhaust manifold
Generator exhaust manifold. The guy seemed to think it was good for mounting a turbo. I've not done boosted engines, so I couldn't say.
This is the mustang intake I plan to use. I might use it as is for now while I source a good Motorcraft 2100 to put on it.
