- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Other
- FLEX-fuel, baby!
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 0" bone stock
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
For a while I've been having to add an inch of coolant to the reservoir every ~500 miles, but that was due to a gunked up nipple on the water-pump, and an aftermarket heater hose... finally fixed that, but still losing a little bit (much less) of coolant. Was under there today (to check if shift rail plugs accessible from underneath), and noticed a drop of coolant hanging front the very front of the trans, just behind that notch/separator plate. Heater hoses to firewall connections are bone dry, so what other coolant "joints" are at the REAR of the engine...
... FREEZE PLUGS?
... FREEZE PLUGS?
