- May 18, 2020
- Burbank,CA
- 4.0 V6
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Every time I drive my ranger, I think of how off the ratios are as I shift. Especially when I can often skip gears. I wonder if they come in different ratios and why they chose the ratios they did. I feel like its always high or low depending on the gear, not much sweet spot.
If I had my druthers here is what gears I would change, pun intended.
1st gear would be much lower.
2nd gear would be slightly lower or same.
3rd gear would be very slightly lower.
4th gear would be same.
5th gear would be slightly taller.
With my slightly larger than stock 31" tires, I cant idle in 1st slow enough for parking lots (gotta keep clutch slipping), and yet still screaming in 5th gear at normal highway speeds (>70mph).
Do all M5OD have the same ratios? If so, why did they choose the ratios they did for these trucks?
