Adding interior LED 4 strip kit
Summers22
Forum Member
Kansas
Has anyone added a RGB LED inteior light kit such as the one I'm posting below? I would like to do an add-a-fuse and have the kit power on with the key on ignition, parking lights or headlights. I dont want to tie up the outlet as it will be used for a cell phone charger. I tried using fuse #11 in the fuse dash panel of my 2001 Ranger, but it eventually caused a drain on the battery. Thanks, Jon
So, if you’re not in too much of a hurry… I’m about to be doing some electrical stuff to my green Ranger including adding lights or at least the wiring for them in the next few weeks along with a bunch of other stuff
I am not in a hurry, I just took the ones out that I had installed, and hooking them directly to a power source, they were dead. Junk I suppose. Anyway, I ordered a different brand (Govee) and will install them eventually. I'll follow your lead when you get around to it @lil_Blue_Ford I appreciate your help!
I'm thinking about tapping into the dome light wiring and adding a couple small LED lights to the rear side panels where the jump seats were.
I'm building a platform in that space.
I'd like to add one under the dash on each side as foot well lights but I dunno if that will be too much to pull from just tapping the existing wire.
I still haven’t got to doing the wiring yet. Well, technically I got started on it, but that start has been to pull my custom center console and all the old wiring plus the radio and it’s wiring, and to start working on my list of circuits/fuses/power taps/relays/etc. It’s a rainy day/when I have a minute or three kinda deal. I have literally days of welding ahead of me right now.
I have several of those.
Exactly what I plan on using.
Not concerned about piggybacking a fuse since a few LED's draw so little amperage.
I'm going to use an add-on fuse/relay block for my front amber fog lights, my rear bumper lights and my bed lights.
Bumper and bed will be LED but the fronts are going to be old skool 6" Hella 500 Series halogens with glass lenses. 😎
