Thank you for the info the truck is a super cab 4x4 with the 4.0 v6 with a automatic trans it is stock so far but I am considering a lift to clear 33 inch tires and regearing to 4.88 gearsNot knowing if you have a reg cab, super cab, 2wd, 4x4, etc I am not going to take wild guesses... check out page 142-145 of the owner's manual, it has the charts with all the ratings.
Yes and not exactly. The lifting methods I suggested are still kind of in the stock realm, so with 4.88 gears it should be not too bad.Doesn't a lift/larger tires effectively kill your legal ability to tow? Since the truck isn't configured per the manufacturers specifications anymore.
I think the trailer is about 17 footI think your max tow rating is somewhere in the 6000lb range.
Being a 2500lb trailer.....youll pry be 3500...MAYBE 4k loaded.
How long is the trailer? Anything over 20ft and sway is going to be an issue even with control devices. The trailer *should* have its own brakes so stopping should be to much concern. The sway will be the killer.
At that weight youre probably in the 17ft range. Remember campers catch ALOT of wind so thats the big factor. I used to tow a 33ft (nose to tail) 7200lb trailer with a 97 F250HD. 460/4.10. I wouldnt of wanted to go much bigger despite only being a bit over 50% of its max tow rating.
That said ive had much more weight behind it on regular trailers and it pulled eaiser then the camper. Just to show you weight isnt the only factor with these.
Personally...id stay away from the lift unless you plan on buying another tow rig.
I think a 17ft is doable.That might be a bit big for a classic Ranger when one factors in wind pushing on the side of the trailer. I know the 2019+ Rangers have had some problems when getting too big even though they were within the tow limits. 17 foot wouldn't be a problem for them since they are bigger and heavier trucks but it might be a bit much for an older model.
