- Feb 13, 2025
- VA
- 4.0 V6
Hey ya’ll,
I’m new here and I just bought a 1993 Ranger with a 4.0 OHV for cheap but it needs a headgasket. The story goes that the previous owner had a bad thermostat and overheated the motor causing it to “blow a headgasket.” From my research on these things, it is very likely to need a new head too. My plan is to replace everything from the piston rings up. I might replace the pistons too but the truck only has 61k miles so I’m going to see how they look first.
What I’m wondering is:
Can I remove the pistons by leaving the motor in and dropping the oil pan then pushing the pistons out through the top.
Has anyone heard of 12degrees north? They have a set of roller rockers with ratios from 1:5:1 to 1:8:1. The set comes with push rods, rollers, and rocker mounting bars. The set is pretty pricy sitting at a price of $1300 so I wanted to know if this may be worth it. If it is worth it would a ratio of 1:6:1 be good to get a bit more lift?
Does anyone know a place where I can get some good valves? I saw the manleyperformance ones listed in the “how to build ford v6” article but wanted to know if there’s any alternatives.
Is the Comp Cams 49-410-8 worth it? If so do I need longer rods? I saw there was a little debate here about if you should do longer rods or not.
Is there anything I should know before I tear this thing apart.
Thank you,
Max
Thank you,
Max
	 Welcome Visitor! Please take a few seconds and
