- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Well i sent them a message asking some questions and requested a data sheet. They only have 3 batteries for cars and trucks. Out of those 3 batteries only 1 has regular car or automotive terminals on it. And there opposite of my terminals. But that shouldn't be to much of a problem. Its the LTO battery Lithium Titanium Oxide witch sounds even more dangerous then Lithium LOL. I will also try calling them and i want to see if there knowledgeable on there products. Here is there technical specs on the battery Listed on there website.
11 Year Warranty Best in class, world-beating, eleven-year manufacturer defect warranty.
Storage Capacity 20 Ampere hours (Ah). Dakota Lithium batteries provide consistent power for all 20 Amp hours. DL LTO batteries have a flat voltage curve, which means they have a steady power output as the battery discharges. The power output will not dramatically drop like similar sized SLA batteries. You get all the juice down to the last drop.
Chemistry Lithium Titanium Oxide (LTO)
Voltage 12.0V
Watt Hours 240
Low Voltage Cutoff 7.5±0.03V
Size 8.15"L X 6.89"W X 7.48"H (207mm X 175mm X 190mm) Group Size 21, but is compatible with battery
sizes: 49, 99, 99R, 102R, 140R
Weight 11.02lbs (5kg)
Terminals SAE Terminal (Standard Automotive Post)
Cold Cranking Amps 1100A (850CCA @ -18°C)
Lifecycles (Battery Lifespan) 10,000 Cycles
Operating Temperature -40°C - 60°C
Max Continuous Discharge 200A 1,000A Max
Max Charge Voltage 15.5V
Max Current Charge 60A
High-Temperature Proctection? -4°F - 185°F (85°C)
Low-Temperature Protection? None
Charge Temperature -140°F (-20°C - 60°C)
Discharge Temperature -40°F - 140°F (-40°C - 60°C)
Approx. Charge Time 6.67 hrs with 3A, 2 hrs with 10A
Internal Heating None
IP Rating IP65
Certifications UN38.3
ISO 9001:2015 Dakota Lithium is ISO Certified per 9001:2015 standards, and select models are produced in ISO 14001 certified facilities.
many moons ago, I had a BMW rocket in the battery was under the rear seat. I never felt the battery was big enough. I ended up making a cardboard box the shape of the available space. I maximize it by removing a piece out of what the Stifter braces that didn’t seem too important. With those dimensions, I could maximize the battery size.
and other thought, the internals are as important as the overall size sometimes a smaller battery can have better power. But back to the BMW I was able to put a much better battery in it. I made a pretty stout plastic shield out of PVC to cover the two terminals so they would rub on the bottom of the seat. When you sat in the seat, you never was there, but the coils would rub on the top.
Not as much work as it sounds, if you’ve got a spotted the trunk or engine compartment or wherever you might want to stick a second one or the bigger
