- Apr 30, 2024
- Moncton NB
- 3.0 V6
I don't want to muddy the waters here and my opinion is by no means gospel but here are a couple things I'd keep in mind re: batteries. The reason they talk about "cold cranking amps" is that a) batteries struggle to provide current the colder it gets and b) starters draw more current when it gets cold - friction, thick oil etc.
Bearing that in mind, on a bad day, a starter is going to pull 300, maybe 400 amps, although I think the latter is a stretch. A 700 amp battery is going to be plenty for just about any starter unless your engine says Cummins on it.
Now, once you get into talking about accidental battery drain, things get complicated, but basically you're into a whole different part of battery chemistry than CCA. Car-starting batteries don't like to be drained very much at all. Without getting deep into it, you get sulfation that damages the lead plates in such a way that they'll never hold a full charge again. So, don't think of more CCA as more reserve capacity, that's what deep cycle batteries are for.
My 2 cents? If you're worried about those rare occasions where something goes wrong and you're in a bind, watch Project Farm's reviews of Li-ion jump packs and grab one of his top rated $60 units and stow that somewhere safe. Rather than chase all over looking for the exact right starting battery, I'd argue that the jump pack is going to be a lot more useful. You might even be able to help your bro out when his Jeep breaks down
