- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Ok, I lied, I actually got something done until I ran out of daylight... I jumped on the tractor and moved dirt that I'd previously worked up with the tiller at the pond... since I already had the box scraper on I pulled the dirt off the top of the berm to lower it like I wanted and put it at the corner that was sketchy on the tractor while I was tilling then the bulk of the dirt I got from just scraping the bottom of the pond into a pile then moved that to some holes on the outside of the pond that I've nearly gotten the tractor stuck in before, then while I was on a roll I took the 8' orchard scraper thing (two adjustable angle plates 3' apart) and flattened out the piles I'd made in those holes, now it's way nicer in a few spots... re reading that it's a lot of blabbing incoherently, I'll see about pictures tomorrow or Monday...
Now I'll just go fiddle fart around the shop for a bit and come inside again for the night
