- Jan 18, 2023
- ontario
- 3.0 V6
- Total Drop
- 1/2
- Tire Size
- 17" with 235/65/17
- My credo
- Mild performance, smooth comfy ride
I have an 07 2WD 3.0 Ranger I'm looking to swap into next summer (or maybe there after)
I recently did a torsion bar to Coil Over front end conversion on my truck and have a Jaguar XJS IRS to put in the rear.
I have picked up a Carbed 302 from a an old truck 70s i believe that was in a an 80s mustang there after and I'm picking up a 03 R2M2 Transmission.
The engine already has serpentine belt pulleys on it and has all the accessories.
I'm looking to get a set of after market gauges (glowshift to match my others, they have a gps adapter for speedo) so I'm not worried about compatibility with my cluster.
I've read through several swaps and the how to do the 302 swap pages and have a general ideas of parts and things to expect to do.
I've scouted out oil filter relocate kits on summit that come out the side not straight and the engine already has a dual pan as it was in a mustang.
I'm looking at getting a set of long tube tri Ys from summit as those seem to be the most consistent I found for easier fitment from my reading.
I haven't scouted a radiator yet but am definitely going to go all aluminum with efan set up.
For the rear gears I was thinking 3.73 or 4.10 gears, my truck will have 29" (currently) or 30" tires. I live in a small town so most the time
it would be highway driving so leaning towards 3.73 gearing.
I read that you can reuse the ford rangers power steering and A/C but doesn't say the years just to get the appropriate brackets should I try to be doing this instead of using what's on the 302?
Mainly I was wondering if anyone had any general advice or recommendations, things they wish they did with their swap or knew about prior to starting swap.
I want to make sure I'm not missing anything silly, main go is for daily drive ability in the the warmer months.
