Steering Shaft Boot
Bob Hatcher
Forum Member
Mountain Top Pa
My steering shaft boot was seriously shot on my 2000 Ranger 2wd and, searching the internet, I learned that they did not make a replacement - I watched a video where someone took one that was close enough and made it work but had to do a lot of cutting to make it fit - I found a universal boot, right around 9 inches, and I just wanted to pass this off to say that it worked just fine - after cutting the old boot off and cleaning the shaft, I only had to slice off 1 small section of the smaller side and it stretched over the shaft where it needed - instead of the steel clamps provided, I just used black plastic ties - I got it from Amazon for 10 bucks - I wish I had a simple part number to pass on but just search for "Universal Replacement rack and Pinion Boot Kit Stretch Steering Rack Boot"
  • Steering Shaft Boot
that looks good. I improvised a used shock boot for mine.
That looks great. Just noticed mine looks like the photo on the left.
I saw a video where someone else used a rack boot but he packed grease in the boot but none into the actual u-joints so it really doesn't do much good - I can see where grease is still in my joints so I left that alone - not like it is rotating at full speed LOL!
Do you have to disconnect the battery when you take the shaft out? I'm never sure what might deploy the Airbag when working on steering components.
In my case, I had no battery in the truck since I am getting the truck ready to install a 302 - with everything out of the engine bay, it is easy to spot defects all around that need some attention
How's the boot holding up, I did the same thing little less than a year ago and the boots pretty much shot from the areas I zip tied.
Also does anyone on here have a ranger that makes like a grinding sound when the turn for me it's more at low speeds and when I turn the wheel to the left. Could the intermediate shaft be going bad?
I haven't been able to install it yet - my main goal, before the winter set in, was to get the 302 bolted to it's mounts in the truck, sealed up & the hood shut and I was able to accomplish that in middle November just before the real cold weather & snow set in - looking forward to getting back to it as soon as the winter weather breaks
Sounds good, build looks good btw
