- Feb 28, 2024
- 3.0 V6
Howdy folks,
I've got an ongoing project that involves deleting these two engine driven pumps, and replacing them with Electric driven ones. No need to discuss the merits of it, but needless to say its happening.
I'll be starting first with the power steering pump, and retaining the A/C compressor for at least a little while, if time and money work out however I'll also be deleting the A/C compressor sometime this year, so I'd like to figure out routing so I can get some belts ordered up and start the fab work that'll go into mounting things.
I'd REALLY love to avoid using dummy pulleys, as the room from the deletes is going to be essential in me actually being able to mount these remote accessories.
1. Power Steering delete only. I'm mainly concerned with the belt coming down from the AC compressor to the main crank pulley. To my eye in vehicle and in diagram, it looks like it'll rub against the tensioner as you can see from my terrible diagram.
Am I missing something? I know the ribbed side of belts can run on smooth pulleys like idler and tensioners, but I just can't think of a way to get this to work with existing pulley locations short of it clearing the idler?
2. AC and Powersteering delete:
The only way I can see this working with stock locations is by using a double sided ridged belt, which who knows if they make them in the length I need. I could delete the Idler pulley and just have the tensioner (With a ridged pulley) using the following routing.
Question is, am I missing something? Am I just a part away from being able to use standard single-sided belts?
If anyone has any ideas let me know!
