1992 Ford ranger looking for headlight
puryear tn
I got a 1992 Ford ranger led headlight assembly or something not just clear was wondering if there was anything like that or a way to make it.
Any cool mods to do to it if there was any
It's not clear what you are asking. Do you already have an LED headlight conversion? Or are you looking for LED headlights for that truck?
I bought these headlights but do not fit and I need that assembly to put on but I was wondering if I can just take the headlight cover off and put the led in or these is a easy setup with led
  • 1992 Ford ranger looking for headlight
If they dont fit id send them back. They clearly state 89-92 and show a 89-92 (or 93/94explorer) in the picture.
Either way they look to be a bolt in replacement for the factory ones....and i hate to tell you but buying ebay headlights like that are a good way to start an electrical fire....or so ive heard.
Okay I will but is there any good headlight that are just different from original I just want something that is seen a lot
Im sure there are but ive never looked into it.
But anything like that can cause issues
I want to buy the same one did you make them fit let me know please I’m tired of the crappy plastic ones
Where did you buy the glass headlamps
LMC trucks website.
They present you two options. Original style sealed beam headlights, and non-sealed beam which you can replace the bulbs in, rather than needing to swap out the entire headlight assembly at a time. Personally I went with the latter because I am a fan of bright headlights and I may swap in Silver Star Ultras when these osrams go out.
LMC trucks website.
Thanks I’ll be most likely doing that
I have another suggestion while I'm at it. There is a rubber (maybe) sort of piece that fits over the outer edges of the headlight assembly. These are nice to have, and if yours are missing or torn/damaged, consider getting new ones from the same site.
Another good site to look into is Bronco Graveyard, by the way.
I sanded mine.
Sanding Grits used: 800,1200,1500, 2000 and 2500.
Finished with a few coats of glossy clear (sorry, no post pic).
Game plan is to upgrade to 9007s.
If I'm not pleased with the brightness, may go projector retrofit.
