I have a 2.9 5 speed ranger. I have made a prior post to this but didn't fix the truck.I stopped fooling with the truck for a while but I'm coming back to it. The truck has a low idle and will die after running for a while. When you give it throttle it misses really bad. Most of the time after giving it throttle it dies too.It had codes for IAT and ECT sensor out of range so I replaced both. This fixed my IAT code but it still says my ECT is out of range. I had to replace ECT connector too.I got the truck to the running temperature and it still says its out of range. I done a fuel pressure test on it and it stays around 40 psi which is what it calls for. I've checked for vacuum leaks, pulled off iac and cleaned it, replaced the fuel filter and probably more I can't think of. One more thing , the fuel pressure relay clicks rapidly after the truck runs for a little bit (I don't know if this is normal or not). I have no idea what else to check.
Any help would be greatly appreciated.
