I would like a bronco 2 but the bronco 1 are easier to find. Should i settle on a bronco 1?
Not getting em to do anything crazy but drive em normally.
There are the Broncos, 1966 thru 1996 earlier ones were smaller but they are considered full size trucks
No Bronco 1's
Bronco II(2) was smaller 1983 thru 1990 similar to Ranger size compared to full size trucks
Bronco name was brought back in 2021 also full size, 2 door and 4 door models
66-73 were not that far off in size from a BII. 3-4spd trans and a brick body kills mileage though. They are also pretty basic even compared to a BII.
How do Rangers have a similar fuel problem compared to the F150 ?That's really only a call you can make. The Bronco is bigger, so more room for stuff inside. The down side is it's going to probably eat more fuel. The Bronco II is going to be more nimble since it is smaller but less room inside for things. Fuel wise, it's probably going to be better but it might not be significantly more better. The Rangers have a similar problem when compared to the F-150. So basically, it comes down to do you want a full size vehicle or a small one?
