- May 8, 2015
- TUCSON, AZ
1985
I found a 2.8 distributor on ebay from Britain for a capri/cortina. It come with a powerspark electronic ignition(similar to pertronix) ,cap and rotor ready to drop in. Shipped,aprox $165.00 and made it in 4 days.
We finished the install today and it works. My truck has never idle smoother and it runs great.
We used the green wire from the stock coil to the module plug on factory distributor. Hooked distributor end to black wire out of new distributor and the coil end to the - on a msd blaster2 coil. Then cut the thicker red wire out of module plug and hooked it to the red wire out of distributor and the coil end to the + side of blaster coil.
I did have to change the plug wires. And i also installed a 2150 non feedbck carb
