1.9L TDI 1997 Ford Ranger XLT
GRoman
EMT / Paramedic
Boosted (Not Stock)
Swansboro NC
4 1/2 inch
36inchs
I decided it was a lovely idea to build a diesel ranger and shove a VW Jetta motor in it, i got it dynoed off cranks at 268 hp 930 lbs. of torque (can you tell i wanted torque). dropped it in my ranger for 26 hundred dollars using a kit specifically for this swap, came with a harness, engine mounts and a tuner. i lifted the truck and shoved a mustang rear end in it and reenforced the front to a f-150 independent. its getting painted victory red in december
Sounds gnarly, let's see the dyno sheet and that full-size front suspension swap.
when i get the truck back from paint ill for sure post the front end here
this was from the wheels before we put the turbo in it
Those power curves are a roller coaster! Holy cow. Is that an OTS tune or custom?
custom, its a shakey tune im planning on fixing it, tdi's arnt easy to tune
Let's see the truck pics.
How did you reinforce the rest of the frame to stop it from turning into a pretzel with that much torque?
Did you get the truck back yet so we could see some pics?
