@Angry Possum ,
• Inexpensive RATES a set of parameters. I will assign <$300/each.
• I will translate "quicker" to increased efficiency.
Based on my assigned cost parameter the changes that will improve the overall efficiency:
1) tear down/clean inspect valve train components (valve covers, rockers, rocker arms and push rods) if serviceable...deburr, chamfer and increase oil passages 1 drill bit size.
2) tear down/clean inspect oil pump internal components; if serviceable...deburr, chamfer and match input/output passages (when pump replacement is required).
3) swap to 16" electric fan.
4) oil filter relocation kit with thermal valve and oil cooler.
5) performance valve job.
6) raise hood rear ¼" to ½", reduce underhood temperatures.
7) know your vehicles fuel economy, when it changes something less than desirable has happened.
8) use all full synthetic fluids; ei, engine, transmission, transfer case and differentials.
