Fender splash guard bolt size
Ozuye10
Forum Member
VA
2004 ranger xl fender splash guard bolt size 5mm is too small and 5.5mm is too big. Nothing SAE seems to fit. About to saw it off 🤬
Give the edges a good wire brushing and try again.
I’ll go buy a wire brush. Is it supposed to be a 5mm bolt?
You could just try scraping the edges good with a flat-head too, no idea what size it's supposed to be though.
The ol Mexican speed-wrench (adjustable) might not be a bad option either.
It's 5/16.
When I went to the pull yard, I wasn't planning on pulling a fender so I didn't have the right size wrench. I went to AZ and bought this:
It worked on a 94.
you might get one of the ends on a screw driver that has removable tips to fit, too
The small ones around the edge
I looked at mine this evening and they are getting to be terrible rough :/
I see what you mean about the small ones, like under the backside on it, I'll see if I can find that
The closest I had was a 7/32. I only have some cheap sets that size that I keep in my yard bag, and it even feels a bit loose in there but not enough I wouldn't use it, hoping it would break it.
I think it won't be long I'll need or want to do some things on mine
I have two sets like that which are one metric, and one set standard
I've found myself using a pair of channel lock pliers. its taking forever but its working.ill probably replace them with 1/4" self tappers
I'd try a 7/32's if you had it. Sorry it took me so long to catch on to this :/
