lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So… when I got my Choptop it was from a former member on here, sherrodwannabeb2, AKA Farva. He chopped the hatch down and used that but I thought it was a pretty poor solution, especially because he didn’t rig up any sort of hinge, so unlatching it the whole thing just came off in your hands. I got a 1st/2nd gen Ranger tailgate and hinges and rigged it up with some latch mounts I manufactured. It’s not pretty and it sorta works, but I want to make some changes.I’m trying to resurrect a chop top given to my brother. It was never finished and has many mechanical issues. 85 base model with a 6” lift.
What do you have as a tailgate? The old hatch cut down or converted to a ranger tailgate. I’m looking for ideas. I contemplated no tailgate but a fake roll bar welded as caps on the rear pillar.
Some kinda notes on things... the body I found isn’t quite stiff enough, mine is starting to show signs of sagging. I started fitting it with a roll cage to stiffen it back up.
I’m not really happy with the chop that was done on mine, I cleaned it up a little back in the day, but didn’t go real crazy with it because I wanted to work out a plan. I don’t quite have all the answers yet, but I have a general idea. I cut Ranger bed rails off at the body line and I cut out the ends with the tail lights and tailgate hardware off a junk bed, going to cut the B2 body and fit that in its place which will clean up the tailgate mounting and cap off the body nicely. Haven’t quite worked out exactly how I’m going to handle the B-pillar area yet, but I think I’m going to flat it off and run a small flange across from drip rail to drip rail. I have the rear section off a B2 I junked that the idea is to fabricate into a sort of cap that I can put on for winter.
The roll cage allows me to rig a sort of wind jammer panel behind the front seats, which is tolerable and can help keep rain off. At the moment I just use a tarp and some clips or currently a piece of canvas. I have a buddy who once I get the chop cleaned up is going to help me with rigging up a proper wind jammer and a soft top for summer.
