2.9 vs 4.0 y pipe flange
jtaborsky
Bismarck ND
4"
32's
Break. Upgrade. Repeat.
Wasn't sure where to post this.
Do 4.0 and 2.9 have same flange on their y pipe? I'm trying to figure out the exhaust on my 4.0 Bronco II. Will bronco ii exhaust bolt up to a 4.0 y pipe?
If your Y pipes both use this style of gasket, then yes, it should.
I am in the process of building the converter side of this on my plasma table. Basically it will be a flat piece that will bolt up to your Y pipe and allow you to use an aftermarket converter rather than the oval shaped nonsense. If you are interested in one let me know, you can be my guinea pig
@jtaborsky
In 1988 Ford changed the 2.9l collector pipe from a dual circular outlet "H", to a 2-1 oval outlet "Y". You can use the 2.9l "H" with your 4.0l, this permits using the stock exhaust.
If you are trying to use the 4.0l's 2-1 oval outlet, it will not bolt onto the BII's stock exhaust without some modification.
Will it be a flat flange with a round outlet to clamp a universal cat onto, or is welding required?
@jtaborsky
Good info. If I use everything after the y pipe from a 1989 or 1990 Bronco II, will that connect to 4.0 y pipe?
The reason I asked this question is the studs on my cat flange are too rusted to thread a nut onto them. Has anyone successfully rethreaded those studs for a smaller nut? My dad is a patient man, but I can tell he's getting sick of me taking up space in his shop!
@jtaborsky ,
The fasteners that bolt the component/sections together can easily be replaced with new fasteners. Just buy some new bolts, washers and nuts.
I have rebuilt Ranger Based Vehicle (RBV) exhausts a few times and never needed to weld one component. Anything can be connected with fasteners or exhaust clamps.
The exhaust from a 88+ 2.9l (Y style), will bolt right onto an OHV 4.0l Y-pipe.
Pardon the crappy picture but this is basically what I am building, minus the studs pictured. I have a few of the flat plates cut already and I could send them like that & you weld a piece onto it to go from oval to round - pretty easy - or I can do that for you and it would look similar to what I did below. Then you can weld or clamp a universal converter to it.
Anyone make a flange to attach exhaust to either pattern? Seems a lot of work for every one of us to one off these flanges and oval pipes, for what should be a relatively easy to make piece.
@jtaborsky ,
HELLO,
If you are still.in need if a solution, I HAVE IT.
Just include my @gaz in your response... I'm on here every couple days or so 🙂
@jtaborsky ,
Here are a couple pics of both flange versions (flange after the manifold pipes, prior to the cats). The oval is from 88+ and the dual 2" is from 86-87.
You may or not be able to see it but the bolt holes nearly align between the 2 flanges; the 2 holes to the right are only ⅛" farther, center to center. Also worth noting, they both use 2" tubing but the oval squishes out some volume from each.
I always thought that it was interesting that Ford had it set up for cross bleed (the H pipe [86-87 version] has a connected passage, where the O² sensor screws in) true dual 2" exhaust but instead sold dual to single???
Im interested in one of these was wondering if i could get one?
Yep, I have a few on hand. $65 plus shipping for a complete assembled piece, $25 for just the flat flange (DIY version)
