- Mar 10, 2012
- 4.0 V6
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
So, I've been threw quite a few threads looking for info. I think I have the answer but I would like some opinions. My 07 has 265k on it and it needs the timing chains done (started rattling recently). I've looked at remanufactured engines as well as rebuild kits. It's expensive either way and the engine needs to come out regardless. My truck is in good shape body wise and I put a used tranny in it with 54k about six months ago. My mechanic said it would cost about $3,500-$4,000 to rebuild it (includes pulling engine) and he would warranty it for three months. A decent kit runs about $900. I looked at putting in a used engine but there is no guarantee and I would still need to do the timing chains. They are not much cheaper than a rebuilt either so a used engine is out of the question! If I rebuilt it I could put some custom heads and cams on it. I could also look for a short block and then put the heads and cams on it too. Obviously it bumps up the cost but not that much. A remanufactured long block runs about $3,000 and $1,800 for a short block. What I'd like y'alls opinion on is this, should I put in a remanufactured engine or rebuild the one in there. Thanks!
